when I turn the Glide potentiometer to the maximum, the keyboard becomes Legato's effect. It is assumed that by holding down the Hold button and moving the potentiometer it is changed from Legato / Glide mode. But in my case it does not work. I have updated the Firmware and it remains the same. I only get legato effect. Can someone explain to me how I can make a slow glissando or if I'm doing something wrong?
Thanks.
Grandmother Glide/Legato problem
Re: Grandmother Glide/Legato problem
I've got the same problem with my Grandmother.
Did you find any issue?
It works fine here, using firmware 1.1.1
Try calibrating the unit, that might make a difference: https://www.sweetwater.com/sweetcare/ar ... nd-update/
http://audiotecna.info
