Hello,
I have an electrical floor noise problem with my Grandmother. It is connected to an Native Instruments Komplete Audio 6 audio card. There is also an Access Virus TI (digital synth) connected to the same audio card.
When I play the Virus, everything is fine, complete silent when I don't play it.
When I play the Grandmother, there is a nasty electrical floor noise when I don't play it.
The Grandmother produces no noise when I play it on headphones. So maybe a cable issue?
I will test all cables, connections one by one but I have (surprisingly enough) lots of them and it could also be a combinaison of more than on cable.
Anyway, has anyone experienced something similar? Any advice?
Thanks.
André
Grandmother electrical floor noise [solved!]
Re: Grandmother electrical floor noise
I'd like to also add that I previously add a Mother-32 and DFAM connected to the same audio card with no unwanted floor noise.
One thing I noticed : if the Grandmother is plugged to the main but switched off, the noise floor is still there. If I unplug it, the noise floor disappears.
Found the culprit!
I disconnect and reconnected everything one by one (hub, printer, hard drives, midi interface, etc) and have finally discover that the OWC Thunderbold hub I was using was causing the floor noise. I got rid of it, used a massive 10-inputs usb hub and no more floor noise!
That's a bit of a weird bug but It is above all big, big relief.
- stiiiiiiive
Re: Grandmother electrical floor noise [solved!]
Welcome and bravo
literally made an account here to say that this post probably saved me from going insaneAndré wrote: ↑Sun Nov 18, 2018 4:41 pm Found the culprit!
Hi I just got the Grandmother a week ago, Ive been trying to record it on Logic through an apogee duet 2. I have this fuzzy hissy sound on the track before i even play any note on the keyboard. I live in Ireland 3 pin plugs etc. How do i get rid of this noise as I can't use the synth like this. Keep it simple and basic if you can please? Thanks much appreciated.
