Mother-32 edit end step
Is it not possible to set the last step of a sequence to a step before the current last step? Example: I have a sequence with 8 steps and want to shorten it to 5 steps. So I edit using SHIFT + RUN/STOP, then SHIFT + SET END, then SHIFT + 5. However, this does not change the last step, it remains 8. What's wrong?
Re: Mother-32 edit end step
Any idea? Thanks!
I think you need to NOT do SHIFT + RUN/STOP first. In other words setting the end point of the sequence isn't considered editing it and you should not be in edit mode. Just do SHIFT + SET END, then SHIFT + 5. If you're in step mode you don't need the SHIFT, just do SET END and 5.
