Moog Music Forum
Share Ideas and Pass the word
Grandmother: Stuck notes using MIDI ports but USB Ok
Tabletop Semi-Modular Analog Synthesizers
Postby zmix » Thu Sep 20, 2018 9:18 am
I've been working with a client who recently purchased a Grandmother and we're experiencing stuck notes when using physical MIDI ports, but when using the USB connection, it's fine..
We're using Logic Pro 10.4.1 with an 8-port MOTU MIDI interface. Any keyboard (including the onscreen virtual keyboard) will cause stuck notes almost immediately, sending a simple quarter note pattern from Logic also causes stuck notes.
I've updated the Grandmother firmware and the MOTU MIDI drivers to no avail, we've tested two Grandmothers so far and both have the same issue.
I have examined the signals being sent to the Grandmother using the "MIDI Monitor" app and there is only not on and note off data in the stream, no clock, or realtime messages.
Has anyone here had this issue?
zmix
Re: Grandmother: Stuck notes using MIDI ports but USB Ok
Postby Ghost1970 » Wed Nov 28, 2018 11:59 pm
Having same problem with this via Mpc1000. You ever figure out?
Ghost1970
Postby ummagumma » Sun Dec 02, 2018 12:44 am
weird, try contacting MOOG?
I have not tried an external keyboard yet, but am planning to use one at some point. will post results here FYI
ummagumma
Return to Grandmother, Mother-32 & DFAM
Who is online
Users browsing this forum: CommonCrawl [Bot] and 4 guests
