by Telharmonia » Tue Dec 18, 2018 6:35 pm
Hi Swannod and Ted,
I just "purchased my Grandmother" last week (that just sounds sooo wrong) and LOVE it.. or rather, her..
However, I also ran into midi issues using Local OFF. Tech support did their best to help, but I was able to confirm several issues with my synth - it does not receive midi note information *properly*, but only in cases when LOCAL control is OFF. All I get is single low droning notes, and so far this is true under ALL of the following conditions:
(1) one plays the Grandmother's internal sounds through it's own keyboard via midi ONLY (local off), as happens when recording through a DAW and looping the midi back into the synth (I'm on Logic Pro)
(2) One plays the Grandmother remotely - as if it were a module - via a midi master controller. (I tried this using *just one* 5-pin midi cable routed from the controller OUT to the Grandmother IN)
(3) One attempts to playback midi performances from the DAW to the synth while Grandmother's Local is OFF.
Swannod, have you tried loading the factory reset file(s)? Before I try it myself, I'm curious if that makes a difference..
Thank you!
Randy
