DFAM Oscillators with M32
stewdio
Post by stewdio » Mon Jan 22, 2018 11:06 am
Are the oscillators the same/similar between the two Mothers? I'm curious if adding a DFAM means I'd be able to make 3 osc patches on the M32 when I'm not using the DFAM for percussion sounds
thanks!
instagram.com/stew_crookes
stewcrookes.com
~ all meters ~ all red ~ all the time ~
stiiiiiiive
Re: DFAM Oscillators with M32
Post by stiiiiiiive » Mon Jan 22, 2018 1:25 pm
Just thinking out loud: to do that, you would need direct oscillators output on the DFAM. Does it have some?
stewdio
Post by stewdio » Mon Jan 22, 2018 3:25 pm
stiiiiiiive wrote:Just thinking out loud: to do that, you would need direct oscillators output on the DFAM. Does it have some?
it appears so from this patch template:
https://www.moogmusic.com/sites/default ... te_Web.pdf
and my thinking is that I could blend the DFAM oscillators with the VC mixer on the 32, then take that mixed output into the external audio in...
stewcrookes.com
stiiiiiiive
Post by stiiiiiiive » Mon Jan 22, 2018 5:09 pm
Right, it appears so. Good news then :)
