Mother 32 Sequencer / Sub 37 Sequencer Question
Pastoral
Post by Pastoral » Fri Feb 03, 2017 9:11 am
Guys,
Can you trigger/sync the Sub 37 sequencer with a Mother 32 sequencer?
Thanks...
Moog Mother 32 System | MF104m | MF105m | MF107 | MF108m | CP251 | Moog Etherwave Theremin | Moog Amplifier
SlowLFOtoPitch
Re: Mother 32 Sequencer / Sub 37 Sequencer Question
Post by SlowLFOtoPitch » Mon Feb 06, 2017 10:25 am
Hello Pastoral,
This can only be done via CV as the CV inputs on the Sub 37 are arbitrary and can be changed to clock the internal arp rate, turn the arp on, etc. This can be done in the Global menu under CV Mapping.
Stevie Ray
Post by Stevie Ray » Mon Feb 06, 2017 6:32 pm
I found it hugely complicated and I couldn't get it to work so I gave up on it.
I'm used to setting up sync between all kinds of sequencers but the M32 and the Sub 37 defeat me.
Pastoral
Post by Pastoral » Tue Feb 07, 2017 12:27 pm
Thanks guys. So it sounds like, yes they can, but it's not very intuitive and straightforward?
bichuelo
Post by bichuelo » Fri Feb 10, 2017 4:56 pm
Pastoral wrote:Thanks guys. So it sounds like, yes they can, but it's not very intuitive and straightforward?
I had to build some cables for the patch cords, otherwise it does seem pretty straightforward and fun!
http://audiotecna.info
Stevie Ray
Post by Stevie Ray » Mon Feb 13, 2017 6:00 pm
I'm going to have another go at it and will report back if I succeed.
Stevie Ray
Post by Stevie Ray » Mon Feb 20, 2017 5:18 pm
Reporting back - I still can't make the M32 and Sub-37 sequencers work properly together and I don't really have time to figure it out.
If someone does work it out, it would be great of you posted up a guide for simpletons like me.
