Program Change causes GLIDE setting to max out.
noCore
Post by noCore » Wed Jan 25, 2017 5:23 pm
Running into an issue here -
I have midi clips in a track in Ableton playing patterns, which are in tern being output to the Mother32.
When I change clips, if the contain any Program Change information - the GLIDE setting on Mother32 seemingly gets cranked to full.
I can turn it down manually and then all is well.. until I change to another clip (with Program Change info) - the glide setting gets cranked again...
(There is no timecode being sent, so the sequencer is not starting/running.)
Has anyone else here come across this behavior?
skrohmer
Re: Program Change causes GLIDE setting to max out.
Post by skrohmer » Sat Jan 06, 2018 6:50 am
A quite late reply ;-), but I got my MM-32 two days ago. Yes, I can confirm this somehow. It happens when I change the pattern, but only when the pattern is different to pattern 1 bank 1. When I select the pattern 1 of bank 1 the glide setting is set back to 0/off. The glide does not affect the sequence, only when playing with the internal keyboard.
Fancyfeast
Post by Fancyfeast » Thu Apr 16, 2020 6:25 pm
I have the same issue when playing midi tracks from Logic. Any response from Moog?
