best way to use M32 sequencer to sequence other synths?
untouchable_888
Post by untouchable_888 » Sat Jul 16, 2016 10:13 am
I know that you need the synth that you wish to receive sequence notes/data to be able to accept CV or have a CV/MIDI converter, but what do I use on the patch bay to connect the M32 to another synth and sequence it?
Stevie Ray
Re: best way to use M32 sequencer to sequence other synths?
Post by Stevie Ray » Tue Jul 26, 2016 8:11 pm
You can use the KB control voltage out and gate out to sequence another analogue synth. I find the results are pretty unreliable with the Mother 32. Scaling/tracking problems even between two Mother 32s.
bichuelo
Post by bichuelo » Tue Jul 26, 2016 8:22 pm
I've had zero problems when using the method you describe to use the Werkstatt as a second oscillator. I must say though, none of my sequences use more than two octaves range
http://audiotecna.info
Stevie Ray
Post by Stevie Ray » Sun Jul 31, 2016 10:09 pm
It might track acceptably over two octaves (if you have a tin ear), but it is not accurate at all. This is the price you pay for 'pure analogue'.
