I'm interested in the Mother 32 -- it looks great. I come from the modular world and am used to CVs being used to modify, well, everything. If I understand things correctly, though, the sequencer is pretty much internal-only -- that is there's no sequencer CV out. But I also heard that there's talk of *perhaps* updating the firmware so that this could come through the assignable out.
First, am I correct that there's no sequencer CV out? Second, does anyone know if there's any real plan to output the sequencer through the assignable out?
One additional question: is it possible to chain sequences? If not, can you switch on the fly? If that's the case, will the sequence you're playing run to the end and then the next one will play, or is the switch immediate?
Sequencer CV out? Thru assignable output? Sequence switch?
