1/8" patch panel to connect mother to foogers
Tabletop Semi-Modular Analog Synthesizers
stewdio
Post by stewdio » Mon May 30, 2016 11:08 am
Does anyone know of a passive eurorack patch bay/tie-line module? I'd like to have all the CV connections of my 3 foogers and sub37 available to the mother 32 with no adapters... Maybe integrate some of my other external gear too - it could break out on the back to DSub or 1/4" or something else even... I've searched all over the internet and can't one...
thanks!
Stew
[email protected]
stewcrookes.com
~ all meters ~ all red ~ all the time ~
Stevie Ray
Re: 1/8" patch panel to connect mother to foogers
Post by Stevie Ray » Mon May 30, 2016 6:33 pm
I just make cables to suit with a 3.5mm jack plug on one end and a 1/4" jack plug on the other (both Neutrik). Does the job for me. Is there some particular requirement you have? I'm pretty sure you can also get passive 3.5mm to 1/4" adapter/mult panels in 5U and Eurorack, but I've never found the need for any myself.
stewdio
Post by stewdio » Tue May 31, 2016 3:39 pm
I find adapters too clumsy - all I really want is some tie lines so that I can easily integrate external synths and processing into a eurorack rig without having to look for the right adapter at any given time... I'd like to have 48 tie lines ultimately so I can access all the audio and CV connections on my non-eurorack gear (like the moogerfoogers which are an akward form factor for quick and inspired patching)
[email protected]
stewcrookes.com
Istvan
Post by Istvan » Tue May 31, 2016 5:02 pm
I've been thinking about picking one of these up, they look pretty handy.
http://www.boredbrainmusic.com
paramnesia
Post by paramnesia » Wed Jun 01, 2016 11:53 am
I'm going to order one or 2 of these after I find 1 in-stock in the USA
http://www.addacsystem.com/product/19-u ... s/addac911
https://www.modulargrid.net/e/addac-system-addac911
Sub37TE V1.2 / 4 X CP-251, 3 x MF-104M, MF-102, MF-107, MF-108M, 4 x Mother32 + 5 x 104HP Eurorack, Windows 7 - 64 Bit | Ableton Live 9.5 + MaxMSP https://www.modulargrid.net/e/racks/view/458782
Stevie Ray
Post by Stevie Ray » Wed Jun 01, 2016 2:52 pm
paramnesia wrote:I'm going to order one or 2 of these after I find 1 in-stock in the USA
They look a nice solution but then they are expensive (you still need to pay for patch cables) and they take up rack space.
A cable with different connectors on each end is not an 'adapter' in my book. To me 'adaptors' are those cheap barrel connectors that always a waste of money.
slabwax
Post by slabwax » Thu Jun 02, 2016 12:42 am
If all you need is down and dirty 1/4" -3.5mm check these out.
http://www.markertek.com/product/sp-m-3 ... -cable-3ft
I've had about a dozen for years and not one has bit the dust.
stewdio
Post by stewdio » Thu Jun 02, 2016 10:24 am
That's a workaround that would make the connection for sure, but what I'm hoping to find is a way to bring all the CV and audio connections of my external gear into the eurorack frame - there's 9 jacks on each of my moogerfoogers and while I can't see using all 9 at once, I have no interest in fishing around the back of them looking for the CV jack I want or having to find one long enough to make it to my sub37, pulling it from it's niche and hunting for which CV jack is which...
I'm not sure why it's such a tall order to just have 48 points of 1/8" connections in my eurorack frame connected to external gear that I can have immediate access to when patching - having to use a mish-mash of cables with 1/4", XLR or 1/8" TRS defeats the purpose of having a standard.
[email protected]
stewcrookes.com
mmarsh100
Post by mmarsh100 » Thu Jun 02, 2016 3:45 pm
If you can solder, this is a great option: https://midisizer.com/other/jack-o-mix/
john21wall
Post by john21wall » Tue Jun 14, 2016 4:11 am
I would like to watch a single video of punching cables on the patch panel which is installed/or to be installed to a rack rather than punching a 5 foot cable sitting in the desk. That's what is most important to see how easy is to fix or work with this patch panel when you have 48 cables in the back of your rack server.
soundshaper
Post by soundshaper » Thu Jun 16, 2016 10:09 am
The Patchulator works pretty well for this exact purpose, and sits well near the Foogers. With two, there are 32 patch points available for CV and/or audio signals.
Here's a video of that configuration scaled down. https://youtu.be/0FWJqe0NS8A
Little Phatty Tribute Edition / Mother-32 / Moogerfooger MF-101, 102, 103, 104Z, 107, 108M / Realistic MG-1
