I have looked around for answers on how to change the default pitch bend range on the Mother, but am not having any luck. The manual is a little unclear on this, in my view.
I'm not sure if it is possible, but I would like to change the default pitch bend range to +/- 2 semitones. My goal is to use this as a third oscillator with my Sub 37, and have several patches with only a +/- 2 semitone pitch bend range. Ideally, I can figure out a way to set this, so if i have different patches with different pitch bend ranges, i can reconfigure the Mother to work with each.MIDI PITCH BEND
MIDI pitch bend messages are added to, or subtracted from the Keyboard CV signal. The Mother-32
default Pitch Bend amount is +/-1 Octave. MIDI Pitch Bend can be output as a -5V to +5V signal on the
Assignable output. This is programmed in Setup mode. See Page 50 for details on assigning Pitch Bend
to the Assignable output jack. MIDI Pitch Bend amount can be set from +/-0 to +/-12 semitones using
MIDI Pitch Bend Depth RPN (CC101 value 0, CC100 value 0, CC6 values 0 to 12)
As far as I know, this may not even be possible, but if anyone knows how to achieve this, i would appreciate any help. Thanks.
