lfo modulation
lfo modulation
Probably a simple question but how do I patch my M32 to use lfo modulation from the wheel of my midi kb? Thanks
Re: lfo modulation
My version:
1. Patch LFO out to Mix2 input.
2. Patch assign output to VC Mix Control input.
3. Patch VC Mix output to VCO Mod input.
4. Set VC Mix knob full CCW.
5. Set VCO Mod Source switch to VCO Mod.
6. Set VCO Mod Amount knob to about 8 o'clock.
7. Set Assign output to MIDI modulation wheel. (Mode 12, MIDI CC 1)
8. Adjust LFO rate and play away.
Re: lfo modulation
Thanks Wesley I'll give it a try.
Re: lfo modulation
Brill! works great thanks Wesley.
Re: lfo modulation
7. Set assign output to midi modulation wheel (Mode 12, Midi CC1)
Hi, Would you like to explain how to do that?
I cannot obtain a result with this config.
Thanks in advance
VD
Thanks in advance
VD
