VCA input trick
VCA input trick
I know some people are bummed that the VCA path point is summed with the internal envelope. I found a work around! It's a little wonky, but if you float the VCA drone/env switch in the middle the VCA is completely silent an you get full control via the VCA patch point. Worked for me sending ADSR env out from microbrute to the mother.
