Moog Music Forum
Share Ideas and Pass the word
Disabling sequencer, is it possible?
Tabletop Semi-Modular Analog Synthesizers
Re: Disabling sequencer, is it possible?
Postby Tonite » Mon Nov 07, 2016 4:06 pm
Hello,
Now I use this small device that let me filter midi events : http://www.audiothingies.com/product/midibro/
Regards
Stephane
Bonus: when I do not use MidiBro to filter midi messages, I use it to generate modulation signal usable through assignable patch input.
Tonite
Postby muleskinner » Fri Jun 16, 2017 1:07 pm
I hope this is being looked at in a firmware update.
I want to be able to slave the M32 to another sequencer's clock but not have the sequence start every time I hit 'play'!
Gonna try that single rest workaround for now...
Noise, Noodles and Doodles: http://bit.ly/mrjonesthebutcher
muleskinner
Postby guzao » Thu Aug 24, 2017 11:12 am
Does anyone found a concrete solution to fix it please ?
guzao
Postby mibolux » Tue Sep 26, 2017 8:27 am
bichuelo wrote:
rudetee wrote:I have created a empty sequence on M32 by entering a rest on step 1.Now when I start Live it does not go bongbongbong....
I did the same and it works
Well yes but it does not play your Midi notes either or?
mibolux
Postby ulverine » Fri Dec 08, 2017 7:01 am
is there a way to disable the sequencer but still get the midi clock from ableton through the assign out on the mother?
ulverine
Postby nolanhaener » Mon Apr 09, 2018 2:12 pm
***Simple Workaround***
Program a blank sequence in keyboard mode, by inputting the hold/rest all throughout the sequence. Length of sequence shouldn't matter, as it will now just play the sequence you have from elsewhere. Save that as your first sequence if you need to.
Hope this works!
nolanhaener
Postby AndreN » Tue Apr 24, 2018 4:09 pm
If I program a blank sequence, external midi notes won´t be played as long as the sequencer with the blank sequence is running. How did you do this nolanheaner?
AndreN
Postby ello » Sun Nov 11, 2018 7:14 am
when trying to filter start stop the arpeggiator doesnt work too. so i use the cv channel of an analog four to process the notes. i guess a midi cv converter is the only real way to go
ello
Postby Lrk » Sat Feb 16, 2019 3:27 pm
Maybe if Moog would like to provide some schematics, i don't mind resolder a jumper or a switch to enable/disable this behaviour.
Lrk
Postby GilbertMason » Mon Feb 25, 2019 8:27 am
I've indistinguishable hindrance from others. I have the Social Entropy Engine as my sequencer and i must arrangement the M32 from here, yet on the off threat that I debilitate Midi alter from the Engine, at that point I are not able to send clock messages to other rigging on that midi port.
GilbertMason
Previous
Return to Grandmother, Mother-32 & DFAM
Who is online
Users browsing this forum: CommonCrawl [Bot] and 2 guests
