Using EHX 8-Step Program with GM
I am a total beginner with modular and am having problems getting this EHX unit to work with my GM. Can anyone direct to the patch points to use for controlling the filter or anything else? I appreciate any help.
- stiiiiiiive
Re: Using EHX 8-Step Program with GM
Hi LosferWords and welcome to the forum!
I've once used the 8SP with analogue synths without any hassle. Consider it as a CV source (no gate, only CV), like an LFO or expression pedal.
Just connect its output to any CV input of the GrandMother, whether it is oscillator pitch input, filter cut off frequency input etc. Then press Play!
The 8SP has several modes, please refer to the manual to configure it. But even without diving in there, you should be able to control a synth parameter.
