960 Sequencer Longer notes on a single stage
dave808
Post by dave808 » Wed Mar 01, 2023 8:31 am
How do you make a longer note on a single stage of the 960, or is it not possible,
or do you have use the Timing on the B-column of the 961 or use the envelope?
I'm a bit stumped with this one!
MRNUTTY
Re: 960 Sequencer Longer notes on a single stage
Post by MRNUTTY » Wed Mar 01, 2023 10:36 am
depending on your intent:
you can use '3rd row control of timing' to adjust sequence step period;
or, a 962 analog switch and a 961 to switch between two B-col delay settings.
2xMother 32, DFAM, Subharmonicon;
