Moog Model 10 Tuning and Warm Up Time
PaulLawler
Post by PaulLawler » Sun Feb 07, 2021 5:31 am
Hi Guys,
I bought the Model 10 last week and have to say it's wonderful in every way, but it's taking approx 4-5 hours warm up time to give me a good 4 octaves stable tuning. I can't get one octave in tune before it warms up properly.
I'm using it with Logic Pro and the Kenton Pro-2000mk2. During the warm up period I can correct the tuning a bit with the Kenton's scaling controls, but once it's warm I set that back to zero.
The only way I can make it stay in tune after this is to not use the Fixed Control Voltage, I leave it set at 1 and then change octaves on the oscillators.
Obviously it sounds glorious once its in tune but it's making it difficult to use in my work, I'm having to have a timer switch it on at 5am :)
Is this normal behaviour, or have I missed some calibration instruction ?
noddyspuncture
Re: Moog Model 10 Tuning and Warm Up Time
Post by noddyspuncture » Sun Feb 07, 2021 1:46 pm
Probably normal... my 901's drift quite a lot, some of them more than others though. Their sound makes it totally worthwhile sticking with them and not upgrading to the 921's.
I modified mine adding a front panel control in the place of the lower of the three inputs sockets on the 901a so I can basically recalibrate 'on the fly' and compensate for any scale drift.
I gig mine and have even managed to compensate during playing.
PaulLawler
Post by PaulLawler » Sun Feb 07, 2021 2:01 pm
They seem ok once they’re warm, maybe the odd bit of overall tuning now and then, just a shame they take so long to become useable.
AlakaLazlo
Post by AlakaLazlo » Sun Feb 07, 2021 3:18 pm
My vintage 2P has 2 sets of 1x901a/3x901b. Takes about an hour to settle in before they stabilize. I bought the system from Sound Arts in the 70s and they added a low tracking pot to the back of each of the 901bs. I get about 5 solid octaves. My Cirklon also has assignable scaling per CVIO out, and using that, I can get 6ish octaves. The range switches on the 901as are pretty much useless as they change the scaling just a bit which throws the tracking off.
Moog IIP, One 16V and MiniMoog, DotCom/FSFX/Moon/STG 110, Cubase 12Pro, Ableton Live 10/64, RME UFX+, 2xMR816, MioXL, Expressionist, Cirklon, Analog Rytm Mk II, Axon AX50, Customized Variax JTV69s (the Hexstainocaster), Strat, Godin ACS Slim, Helix.
PaulLawler
Post by PaulLawler » Sun Feb 07, 2021 3:39 pm
Does a tracking pot alter the sound in any way if it's correcting tuning ?
ummagumma
Post by ummagumma » Sun Feb 07, 2021 8:38 pm
curious if anyone has improved the range switch circuits on the 901a's, to make them more accurate?
PaulLawler
Post by PaulLawler » Mon Feb 08, 2021 4:42 am
I managed to create a good in tune tracking via the Kenton Pro of around 3 octaves, this is in the first warm up hour so a huge relief in that sense.
EDIT: I'm having to create a new scaling preset per hour, I guess it is slowly expanding it's range.
ummagumma
Post by ummagumma » Mon Feb 08, 2021 6:28 am
may be a dumb question, but do you have it located for example: ogainst an outside wall, in winter? or near a baseboard heater/some other place in your house where temp is not stable?
PaulLawler
Post by PaulLawler » Mon Feb 08, 2021 6:36 am
It is around 10 inches from an outside wall and it is pretty cold outside currently. My studio is heated though, not overnight of course. I'm pretty sure none of that is helping, I've just not had anything that behaved like this before so wanted to make sure there wasn't an issue or fault that could be looked into first, or even something I could do more, like some kind of calibration ...but then again would that even work as it's pretty much a moving target for the first half of the day.
ummagumma
Post by ummagumma » Tue Feb 09, 2021 2:12 am
I wonder if you took the back off, it would stabilize faster?
speculating here: but if the space is unheated overnight, it has time to get cold inside the case
then when you turn the heat on during the day, because the model 10 is sealed inside a box, it takes a long time for the room temp to reach the inside of the case & stabilize the oscillators
PaulLawler
Post by PaulLawler » Tue Feb 09, 2021 4:28 am
I'm going to try one of those survival heat blankets tonight see if it helps. But in your opinion does this not seem normal for 901s then with you suggesting removing the back ? I have contacted Moog a couple of times but got no answer yet. The store does have another in stock if it's a fault.
ummagumma
Post by ummagumma » Tue Feb 09, 2021 10:41 am
well to be honest I do not have one, so I am only guessing
but based on what I have read about temp instability of early oscillators, I would guess your problem is related to the environment?
maybe leave the heat on overnight & see if it helps?
or possibly the store could let you try the other one & see if it behaves the same, in your space?
AlakaLazlo
Post by AlakaLazlo » Tue Feb 09, 2021 8:43 pm
I was thinking about this earlier today. It is very possible that some of your tuning issues are due to temperature fluctuations.
In 79, I was crazy enough to use the IIP on stage at the Troubadour in LA. Every time a spotlight was on me, it also hit the Moog and the tuning when to s*&t. Last time I used it live...
I have the backs off both my vintage P Cabinets. (Never actually had them...) They are about 6 inches from a wall, but that wall has been covered in acoustic foam (which is a great insulator). With the backs off, there is no heat buildup. Once the room heats up in the morning, the temp is pretty stable throughout the day. My system stabilizes pretty well in about an hour and stays that way until I shut it off.
Rarecomponentadsr
Post by Rarecomponentadsr » Thu Feb 11, 2021 2:26 pm
I made natty little thermal jackets out of thick packing foam for the relevant transistors in the 901a/b ‘s
Seems to help and worth it for the sound of the 901b’s.
Takes an hour and costs nothing.
ummagumma
Post by ummagumma » Thu Feb 11, 2021 5:07 pm
are the oscillators more stable when warm, or cool? or it doesn't matter, as long as the temp is constant?
thinking of a small HVAC unit with a thermostat.....you could build a little beer fridge inside one of those cabs! :)
