by CZ Rider » Sat Jan 06, 2018 12:08 am
There was a discussion a while back in this thread;:
https://forum.moogmusic.com/viewtopic.php?f=1&t=21687Since that time I did complete several portable cabinets. I made my own mounting strips from aluminum stock. Very similar to those Dotcom 19" rack mount rails.
Here are the parts I used to construct my rails using 1/4" square aluminum stock with 6-32 tapped screw holes. Moog used 6-32 X1/4" truss head screws.
Used 1/2" aluminum L stock and aluminum sheet metal to construct the mounts.
View of front.
Finished, my mounting plates looked like this.
Mounted in the cabinet.
Close up of the top rail, similar to the wood cabinet type mounting.
The 1/4" aluminum square stock worked well for my mounts. Just had to drill and tap.
