Moog Music Forum
Share Ideas and Pass the word
Moog 15 with 2 Filters and pedal modulation....
Postby elcatllar » Sun Jul 09, 2017 4:54 am
I saw sometime ago in youtube a moog modular demo where they used 2 lowpass filters thru the same VCA,.The sound was amazing!
Now I have just bought one Moslab LPF + a 921.
2º LPF : The way to do this in my 15?. I have made some test and I am do something wrong.
921: I have this second 921 Moslab for modulation purposes. Can I use a voltage pedal to control the vibrato form this 921?
And finally : Some comments about the use of the 15 + the Arturia keystep?.
Thank you in advance.
elcatllar
Re: Moog 15 with 2 Filters and pedal modulation....
Postby EricK » Mon Jul 10, 2017 8:26 pm
Can you link to the youtube video you are referring to?
And if you use the Aux out on your 921 you can attenuate the voltage that way.
Postby rzzzzz » Sun Jul 16, 2017 12:00 am
w/o the video you're referring to, i can only speculate that you might combine a filter on the 923 cluster along with the 904.
rzzzzz
Postby elcatllar » Thu Jul 20, 2017 2:24 pm
Dear Erick
Please see the link:
https://www.youtube.com/watch?v=KZugJDqNXYQ
See the 5,00 min.
I have tried and something is wrong! GRRRR!!!!
My current system is : Moog 15 + Moslab 921 + Moslab LPF.
Let me know what will be your suggestions about the patching with my system.
Jan
elcatllar
Postby EricK » Fri Jul 21, 2017 11:31 am
Jan,
His configuration is a little different.
He has 6 901bs going off of one 901a controller and he's just using 2 mixers and 2 filters to separate them.
You need to have your pitch controlling your 921a AND your 921s, so you'll have to multiply your pitch CV first.
Then you have to multiply your envelope to accomplish the sweeping filters.
But the problem arises from the fact that you only have 1 mixer. So you might want to use your second VCA. So you'd have to multiply the VCAs control signals (the 15 is duophonic) and then send the VCAs outputs to a mixer, pan them.
Let me think on it a bit more and get back with you. Maybe someone else can chime in.
Return to Modular Forum
Who is online
