Hello,
Maybe its a stupid question but as I understand the 921 can be used as an audio source or as a lfo. Can I use both unlike the minimoog ? where you need to choise to use the 3º mini oscillator as audio or as a lfo to get a vibrato for example?
Thank you in advance
Moog 15 - 921
- noddyspuncture
Re: Moog 15 - 921
Yes of course you can, in theory... but as LFO's are normally also varied frequency-wise for the effect, it would also alter the "pitch" (which would be most probably set to low/sub-audio anyway..) making it not so useful for audio duties while being used as an LFO... if that makes sense...?elcatllar wrote:Hello,
So really it's the same as the Minimoog... either/or is most likely.
Tom
