Hello All,
I have noticed an issue with my werkstatts vco this evening. There are two small points when turning the pitch knob where the pitch goes "bad". At around 11 o'clock on the pitch knob the pitch jumps up much higher than it should be and sounds really bad. This also happens around 12 o'clock. So there are little spots that sound terrible when moving the pitch around. I opened up the werkstatt and sprayed the pot with dioxite but that did not change anything. Does anyone have any idea about what is going on with it?
