Moog Music Forum
Share Ideas and Pass the word
wonky expansion board, no eg?
Everything Werkstatt.
Postby BrianMadigan » Wed Sep 13, 2017 5:42 pm
I have been using the werkstatt as a second osc and mod source for things like Mother 32 and Korg's new MS-20 mini. I have the CV expansion board installed KIND OF, it's not very stable and requires some pushing and rocking occasionally to work. I need to make a custom panel for the thing so I can eurorack it.
The other issue I'm seeing is nothing coming from the EG. I can't get the EG to modulate anything. I should probably hook up a scope and see what's going on, but I think the EG only works when the keyboard is triggering it. Is that right or is there a way to externally trigger the eg?
I still need to calibrate the thing.
BrianMadigan
Re: wonky expansion board, no eg?
Postby nathanscribe » Sat Sep 16, 2017 4:10 am
Two things trigger the envelope: 1) a button push on the Werkstatt's own keyboard, 2) an external gate. You can hook up a positive voltage to the Gate Out on the header, which doubles as an input because Moog didn't include a true Gate Input.
I did a mod for this, link in my sig if you're interested. Lack of a true Gate In is a problem but you don't need it for use purely as a 2nd VCO in a larger system. All your dynamics will be controlled elsewhere. I use mine as a 2nd VCO in a modular setup and just take the raw VCO out from the Moog into the filter on my other synth. Works fine, tracks well.
nathanscribe
Return to Werkstatt Forum
Who is online
Users browsing this forum: CommonCrawl [Bot] and 2 guests
