Moog Music Forum
Share Ideas and Pass the word
Werkstatt Knobs
Everything Werkstatt.
Werkstatt Knobs
Postby DeniseK » Thu Jun 16, 2016 2:43 pm
Hello to the forum,
this is my first post because I have my first Moog now. :D
It is a Werkstatt.
I sequence it with my Analog Four and the A4 is also used for the Werkstatt as the effects unit.
Now my question.
Is there any possibility to pull off the fiddly knobs (like Korg Volca style :x ) and pull some real nice knobs on them like the Minitaur has?
DeniseK
Re: Werkstatt Knobs
Postby sbell.sd » Sat Jun 18, 2016 11:20 am
Here was a thread that asked if "Is the werkstatt is more than a toy?"
http://forum.moogmusic.com/viewtopic.php?f=17&t=22063
This thread was taken off topic, hijacked by exterior decorators, and their apparent opinion is that if you add larger buttons to anything it can not be considered a toy.
sbell.sd
Re: Werkstatt Knobs
Postby Struble » Sat Jun 18, 2016 1:33 pm
I've bought knobs off of synthesizers.com to make my Wekstatt look officially more Moog-like. The knobs do cover up the labels, but damn if it doesn't look good.
http://DepressedBoy.com
Equipment: Moog Werkstatt; Arturia Microbrute; Syntecno TeeBee; Elektron Sidstation; Korg Volca Keys, Electribe ER-1, Monotron; MidiNES; Teenage Engineering PO-12; Roland Boutique JP-08; BeatStep Pro; GameBoy
Struble
Re: Werkstatt Knobs
Postby DeniseK » Sat Jun 25, 2016 3:05 am
Pics please :wink:
DeniseK
Re: Werkstatt Knobs
Postby GregAE » Sat Jun 25, 2016 7:54 am
The knobs from synthesizers.com are all 1", but you can get smaller versions from Small Bear Electronics:
http://smallbear-electronics.mybigcomme ... led-shaft/
Be aware that knobs come in two basic types; the 'press-fit' type for knurled shaft pots and the 'set screw' type for smooth shaft pots. Make sure you are ordering the correct type.
I've used both types for some recent re-knobbing projects:
On a modular panel:
On a vintage synth:
EDIT - I believe these are the same knobs that Moog uses on the M32 and Sub 37.
KnobTweak - The Moog Gear & App Resource
A place to share Patches, Setups, Techniques, Instruction, Ideas and more...
http://groups.yahoo.com/group/KnobTweak
GregAE
Return to Werkstatt Forum
Who is online
