Moog Music Forum
Share Ideas and Pass the word
Using headphones with Werkstatt-01
Everything Werkstatt.
Postby krcm0209 » Mon May 02, 2016 6:52 pm
I'm just getting into synths and music as a whole, for experimentation, learning, and fun. I have a Werkstatt being delivered tomorrow and I was wondering how I could use it with my headphones. Would this do the trick? http://www.amazon.com/Behringer-MA400-BEHRINGER-MICROMON/dp/B000KUCQXY/
I want to be able to experiment and have fun without being at my computer all the time. Just kinda have the Werkstatt setup with something I can go over and plug my headphones into and play around.
krcm0209
Re: Using headphones with Werkstatt-01
Postby paramnesia » Tue May 03, 2016 8:29 am
i would buy this adapter instead and plug headphones directly into the Werkstatt-01.
http://www.showmecables.com/product/1-4 ... apter.aspx
The mixer is unneeded. The Werkstatt-01 has line output on 1/4" TS jack, which will power most headphones, but only 1 side. The mono-to-stereo adapter will allow sound on both sides of headphones.
Sub37TE V1.2 / 4 X CP-251, 3 x MF-104M, MF-102, MF-107, MF-108M, 4 x Mother32 + 5 x 104HP Eurorack, Windows 7 - 64 Bit | Ableton Live 9.5 + MaxMSP https://www.modulargrid.net/e/racks/view/458782
paramnesia
Postby krcm0209 » Tue May 03, 2016 12:49 pm
paramnesia wrote:i would buy this adapter instead and plug headphones directly into the Werkstatt-01.
Just tried plugging the headphones in with an adapter I borrowed from a friend. I could hear the synth, but the volume is pretty low. If I wanted to amplify the signal to the headphones would I have to buy what I posted, or is there a better alternative?
krcm0209
Postby paramnesia » Thu May 05, 2016 12:09 pm
krcm0209 wrote:If I wanted to amplify the signal to the headphones would I have to buy what I posted, or is there a better alternative?
i would not buy the mixer linked, i think it's too basic to be usable, and appears to be designed to convert an existing signal from another mixer into headphone level
check this http://www.sweetwater.com/insync/mixer-buying-guide/
you need a basic analog live sound mixer, with extra channels and features to grow your hardware setup if you plan on adding other equipment: reverb, additional synths, microphones, sampler, drum machine, Mother32...
alternatives priced Low to High
http://www.sweetwater.com/c264--Analog_Mixers/low2high
my fav analog mixers:
Mackie VLZ1202 http://mackie.com/sites/default/files/p ... index.html
Allen & Heath MixWiz 16 http://www.allen-heath.com/ahproducts/wz4-16-2/
Allen & Heath Xone464 http://www.allen-heath.com/ahproducts/xone464/
APB ProRack House http://www.apb-dynasonics.com/products/ ... House.html
APB ProRack Monitor http://www.apb-dynasonics.com/products/ ... nitor.html
paramnesia
Return to Werkstatt Forum
Who is online
Users browsing this forum: CommonCrawl [Bot] and 1 guest
