Moog Music Forum
Share Ideas and Pass the word
Do I have a glitch?
Everything Werkstatt.
Do I have a glitch?
Postby aarmcm » Tue Oct 27, 2015 1:44 pm
So this seems strange to me, When I have then Envelope sustain switch off, and Attack turned up past about 9 O'clock I no longer get envelopes generated on key press.
With attack zeroed out, I can trigger the decay phase as expected. But turning up the attack lowers the peak value until it is inaudible about 9 O'clock.
Should I RMA, or is there maybe just a trace that can be repaired?
aarmcm
Re: Do I have a glitch?
Postby Wesley » Wed Oct 28, 2015 12:06 am
This is normal operation.
Wesley
Postby Vsyevolod » Wed Oct 28, 2015 2:56 pm
I have been wondering the same thing and have come to the conclusion that this is normal. Partly because that's the way it works with both my Werkstatt's... :)
Here's my theory as to why it works this way:
Turning the 'Sustain' switch off makes a very short pulse driving the envelope generator. Another way of saying this is that the 'window' changes from however long you hold the key down to a non adjustable short window. At the end of that pulse, the release kicks in (the Werkstatt refers to it as 'decay' even though Moog is the originator of the ADSR terminology...). Unless your attack is short, there's just not enough time for the envelope to open up the VCA very far. It would be nice if the attack section were allowed to develop and trigger the release when it came to full blossom but I don't think that's how the circuitry has been designed.
Perhaps someone will design a mod that switches from current behaviour to a three way switch that allows sustain/short pulse to trigger the attack/full attack blossoming(trigger at the end of the attack cycle).
Stephen
Vsyevolod
Postby aarmcm » Tue Nov 03, 2015 11:02 am
Thanks. That makes sense electrically, but not musically. :(
Sure wish I could trigger an AD envelope.
aarmcm
Return to Werkstatt Forum
Who is online
