Moog Music Forum
Share Ideas and Pass the word
Test point question
Everything Werkstatt.
Test point question
Postby dmk » Wed Apr 08, 2015 9:17 pm
I was planning on trying out the photoresistor mod tutorial but found myself thwarted on the first step: I discovered that my test points didn't have any holes. I wrote customer service concerning this (the manual states "plated through-hole test points are provided") but was told that this is normal and I'd have to clear it manually with a soldering iron and desoldering braid. Is this right?
I am a total novice at this but gave it a swing without success. I had the soldering iron at 600˚F and applied it to the test point for upwards of 20 seconds and with no change. I have both a sucker and a braid. I really don't want to bust my Moog. How high should I bring the temperature up to? And I suppose it shouldn't take that long for it to melt, right?
Thanks for your help,
k
dmk
Re: Test point question
Postby kenzak » Thu Apr 09, 2015 10:57 am
20 seconds is too long. Be careful...
I'm still learning and this video helped me: https://www.youtube.com/watch?v=Z38WsZFmq8E.
I'm not sure if the Werkstatt solder is lead free. If it is you probably need to go a bit higher on the temperature. Either way, I would suggest you practice removal on something disposable (I used some demo PCB's from where I work).
Good luck and have fun!
Ken
kenzak
Postby dmk » Thu Apr 09, 2015 12:35 pm
Rad, the video was extremely helpful. Among many other tips, I realized I had no idea how to use the braid. As suggested on the 4:25 mark, I'll try dialing it up to 700˚F and see what happens. Maybe I'll swing by a thrift shop and pick up a junk electronic or two to practice on too—that's probably the best tip.
Thank you!
dmk
Return to Werkstatt Forum
Who is online
Users browsing this forum: CommonCrawl [Bot] and 2 guests
