Werkstatt has stopped functioning
Everything Werkstatt.
arjanhoekstra
Post by arjanhoekstra » Tue Nov 04, 2014 7:11 pm
My Werkstatt will not switch on as of today. Nothing happens when I plug it in. I have tried to measure a few points but really this goes beyond my expertise. Anyone able to help me or share some tips on how to resolve this problem? They will be greatly appreciated. Thank you.
grenert
Re: Werkstatt has stopped functioning
Post by grenert » Tue Nov 04, 2014 10:00 pm
Has the Werkstatt been modded?
Do you know the power supply is working? If you have a multimeter, check that it is putting out 12V as expected.
muksys
Post by muksys » Tue Nov 04, 2014 11:08 pm
Are you using the power supply that came with the Werkstatt or a different one? I've killed 2 Werkstatt's and found that I was accidentally powering it with 9VDC from my benchtop power supply. The fix was replacing a burned out resistor. Check at R17 which is a 4.99k resistor. It'll look burnt if it's dead. Other than that do what grenert suggested my making sure the power supply is outputting 12VDC.
When you say nothing happens, does that mean the LFO LED doesby light up?
arjanhoekstra
Post by arjanhoekstra » Wed Nov 05, 2014 12:24 am
Thank you grenert and muksys.
grenert wrote:Has the Werkstatt been modded?
The workstatt has not been modded nor been tampered with. All that's been done to it is I've added a jumper cable to one of the pcb screws just like is shown in the video's on the werkstattworkshop website. I am using it's original power supply which measures an output of 12.16 Volt DC current.
muksys wrote:When you say nothing happens, does that mean the LFO LED doesby light up?
Yes, exactly that. No LED light and no sound coming from the Werkstatt.
At R17 I measure 29.4 the reading seems to vary between 24 and 30 at random. I've taken a picture, does it look burned?
Werkstatt pcb R17
Werkstatt pcb R17
Reading at R17
Reading at R17
I also measured 12.3 Volts with the black probe at center+ (15) and red at the one below. But when the red probe is moved over to TP15/16 I get a reading of 1.637
Thanks guys
muksys
Post by muksys » Wed Nov 05, 2014 9:20 am
A resistors value can't be measured when it's part of a circuit. R17 needs to be removed to test it. It's hard to tell in the picture but it does look a little toasty.
The way to check the voltages is to stick the black probe on tp11 or 13 and use the red to test the different voltages. Positive voltages will read 12, 9 or 5. Negative voltages will read -9. Make sure you have the probes plugged into their corrisponding terminals on the meter. The black should be plugged into to COM port.
bichuelo
Post by bichuelo » Wed Nov 05, 2014 9:27 am
I'm no expert but it looks burnt to my sight
http://audiotecna.info
grenert
Post by grenert » Wed Nov 05, 2014 10:03 am
muksys wrote:Check at R17 which is a 4.99k resistor.
Just a clarification, this resistor should be 4.99 ohms, at least according to the schematic (and the resistor itself looks to be marked 4R99).
With the power supply plugged in, put the ground lead (black) of your meter on a ground test point. Then put the red lead first on the left terminal of the resistor and measure DC volts. It should be around 12V. Then move the red lead to the right end of the resistor. It should still be around 12V.
arjanhoekstra
Post by arjanhoekstra » Wed Nov 05, 2014 11:54 am
muksys wrote:A resistors value can't be measured when it's part of a circuit. R17 needs to be removed to test it. It's hard to tell in the picture but it does look a little toasty.
I agree with you there it does look a little toasty.
muksys wrote:The way to check the voltages is to stick the black probe on tp11 or 13 and use the red to test the different voltages. Positive voltages will read 12, 9 or 5. Negative voltages will read -9. Make sure you have the probes plugged into their corrisponding terminals on the meter. The black should be plugged into to COM port.
So I've just measured all voltages the way you've described. +12 reads 1.637vdc. +9 reads 0.231vdc. -9 reads -2.050. +5 reads 0.591vdc. Anything else I should look at?
Just done exactly as you say. Measuring 1.636 on the left side and 11.90 on the right side of the resistor.
Thanks guys, much appreciated
muksys
Post by muksys » Wed Nov 05, 2014 12:11 pm
Yep, my mistake. It's 4.99 ohms. Sounds like it's dead. If you're not comfortable with doing SMD desoldering, this is something I can fix for you if moog won't warranty it.
Control_Voltage
Post by Control_Voltage » Fri Nov 07, 2014 9:54 am
Hi there,
Andy Hughes from Moog Music here!
If the Werkstatt has not been modded, we will of course be happy to perform this repair under warranty at no charge, and give the unit a full test to make sure there is not a fault somewhere else on the board that caused the resistor to burn, and we will check your PSU as well.
Please contact me at [email protected] or by phone (828)251-0090 xt. 221
Thanks,
Andy Hughes
Tech Support Manager
Moog Music, Inc.
grenert
Post by grenert » Sun Nov 09, 2014 12:18 pm
muksys wrote:Are you using the power supply that came with the Werkstatt or a different one? I've killed 2 Werkstatt's and found that I was accidentally powering it with 9VDC from my benchtop power supply.
Wow, I almost just did this exact same thing. :shock:
Fortunately, I have enough experience frying circuits that I smelled that something was wrong and pulled the power supply before the resistor was fully fried.
I haven't really looked at the Werkstatt power supply circuit, but what a weird thing that giving a LOWER voltage to a device causes problems!
arjanhoekstra
Post by arjanhoekstra » Thu Nov 27, 2014 11:35 am
This issue has been resolved. Thanks to everyone posting in this thread and the excellent service at Moog music.
muksys
Post by muksys » Sat Nov 29, 2014 12:03 am
arjanhoekstra wrote:This issue has been resolved. Thanks to everyone posting in this thread and the excellent service at Moog music.
What ended up being the issue?
arjanhoekstra
Post by arjanhoekstra » Sun Nov 30, 2014 4:29 pm
Burned resistor at R17. I don't know how this has happened, as mentioned, no modifications where done to the Werkstatt.
muksys
Post by muksys » Sun Nov 30, 2014 8:42 pm
Interesting. That resistor is sensitive. I've fried it out from using a wrong power supply to shorting contacts to ground. I've never had a PS on a syth with such a sensitive part. Seems like a bad design choice for something thats intended to be user modifiable.
