Moog Music Forum
Share Ideas and Pass the word
Moog ladder cutoff knob range?
Analog Delay • Ladder Filter
Postby iksrazal » Tue Apr 29, 2014 3:55 pm
Hi all, quick question:
I can't find out for certain what the notches under 200HZ are. For example, the lowest little white line around the cutoff knob, all the way to the left, is that 40HZ? And every notch all the way to 200HZ are in 20HZ increments? And from the lowest marked notch until the knob no longer turns ... is that 40HZ to 20HZ?
I would like to set the HPF cutoff at 30HZ sometimes and I am not clear on what the setting for that is.
iksrazal
Re: Moog ladder cutoff knob range?
Postby Moog Music » Thu May 01, 2014 4:55 pm
The Cutoff on the Ladder 20Hz-20k.
Hope this helps,
- Your Friends at Moog
Moog Music
Return to 500 Series
Who is online
Users browsing this forum: CommonCrawl [Bot] and 1 guest
