Moog Music Forum
Share Ideas and Pass the word
MF Ring fizzles/clips out and high pitched feedback
Welcome to the world of Minifooger Analog Effects
Postby wafflefoot » Sun Aug 11, 2019 6:18 pm
I'm no longer able to keep the miinifooger MF RING on my pedal chain cause it just won't power on correctly anymore after clipping out and fizzling in a way. It worked fine when I first bought it but from the beginning but still had a high pitched feedback that's in the background but still pretty audible. I thought maybe that's supposed to happen but after reading some forums I see that that's not what's supposed to happen. After looking at some other complaints about these pedals it seems it's just a fluke with a bad component maybe? I haven't tried to use a battery yet to see if it's a power adapter issue. It also seemed to fry my original 1spot power block but that could've been unrelated. But also the 13mA is different from the other pedals I have chained on my 1Spot. Any solutions for this? Or a test to diagnose where the issue is stemming from? tHANKS
wafflefoot
Re: MF Ring fizzles/clips out and high pitched feedback
Postby wafflefoot » Mon Aug 12, 2019 8:17 pm
So I figured out from the seller that it requires a center positive power supply when I was using it in my regular center negative 1spot chain. Will the diode be irreversibly damaged or will I be able to use a center positive adapter in my chain to correct this? Even though the effects worked fine with my 1spot before, it always had an undesirable high-tone feedback behind my guitar signal..so now it still kind've turns on but makes a terrible feedback and isn't playable at all on a boss style power supply, once I realized the polarity was wrong though I stopped plugging it in..so thanks in advance.
wafflefoot
Return to Minifooger Forum
Who is online
Users browsing this forum: CommonCrawl [Bot] and 5 guests
