Using with Voyager RME
Welcome to the world of Minifooger Analog Effects
mrkeeny
Post by mrkeeny » Thu Dec 29, 2016 7:24 pm
Hi all,
I currently connect my RME to audio interface via balanced TRS lead.
I have purchased a minifooger delay and confused as to how I need to connect it all up.
Is it possible to incorporate the fooger while retaining the balanced connection?
Or, am I right in thinking that minifoogers only use unbalanced 'patch' leads ?
So, I will have to connect the output of the RME to the fooger with an unbalanced patch lead, and then connect the fooger to my audio interface using another patch lead?
Any advice appreciated as I can't seem to find anything definitive elsewhere.
Martin
bichuelo
Re: Using with Voyager RME
Post by bichuelo » Thu Dec 29, 2016 9:30 pm
I don't thing the RME has a balanced output. The ring is not connected anywhere inside its output jack. Check page 6 in the manual, it never speaks of a balanced output...
http://audiotecna.info
mrkeeny
Post by mrkeeny » Fri Dec 30, 2016 6:10 am
Hi, yes it does, on the RME only. See the switch in pic
http://medias.audiofanzine.com/images/n ... 453512.jpg
