Moog Music Forum
Share Ideas and Pass the word
Minifoogers you would like to see in the future
Welcome to the world of Minifooger Analog Effects
Postby MagicMoogMan » Sat Apr 18, 2015 10:24 pm
The Minifooger line is obviously successful. What Pedal(s) should they make in the future?
My vote goes for a Minifooger Phaser based on it's big brother. I'd buy that in a second!
MagicMoogMan
Re: Minifoogers you would like to see in the future
Postby mmarsh100 » Tue Apr 21, 2015 6:54 pm
Filter.
mmarsh100
Postby bichuelo » Tue Apr 21, 2015 7:42 pm
mmarsh100 wrote:Filter.
the Drive has a resonant filter and you can tweak the cutoff it via the CV input
http://audiotecna.info
bichuelo
Postby DonutDude » Tue Apr 21, 2015 7:50 pm
I'd like to see a State Variable Filter in either a Minifooger, or a Moogerfooger.
DonutDude
Postby bichuelo » Tue Apr 21, 2015 7:54 pm
DonutDude wrote:I'd like to see a State Variable Filter in either a Minifooger, or a Moogerfooger.
Is there one of those on any Moog gear? At least the way the Voyager does the high-pass is not exactly that, nor on the 500 series filter, or is it?
bichuelo
Postby Alien8 » Tue Apr 21, 2015 9:14 pm
4 stage phaser with mix, depth, rate and shape knob. Exp input for rate / depth or mix.
Alien8
Postby mmarsh100 » Tue Apr 21, 2015 10:49 pm
It's not *that* filter.
mmarsh100
Postby MoogProg » Fri May 01, 2015 7:19 am
mmarsh100 wrote:It's not *that* filter.
But it works nevertheless! I use the MF Drive as a filter for the MicroBrute, and it certainly does lend a 'moog' sound quality to that synth, and can be controlled by its ENV or LFO just like an on-board filter.
Now, the Minifooger I'd like to see (other than the obvious build-us-a-mini-phaser-now request), would be a stand-alone LFO to modulated the existing Minifoogers. Amiright?
MoogProg
Postby Gladmarr » Fri May 01, 2015 2:46 pm
I second that! If Moog made a state variable filter, you know it would be good!
Gladmarr
Postby Croyote » Sat May 02, 2015 5:15 am
Just order a CoPilot Broadcast. It actually has tap tempo, which Moog hasn't bothered to include in the Minifooger line.
Croyote
Postby MoogProg » Tue May 05, 2015 2:39 pm
Croyote wrote:Just order a CoPilot Broadcast. It actually has tap tempo, which Moog hasn't bothered to include in the Minifooger line.
^Thanks for the tip! Have ended up using a MicroBrute for all these feature (plus MIDI sync), and am currently sending its LFO CV and ENV CV out to a Slim Phatty to add modulation options. Winning!
MoogProg
Postby ColorForm2113 » Tue May 12, 2015 11:39 am
Murf and bode frequency shifter :D
ColorForm2113
Postby Croyote » Fri May 29, 2015 10:44 pm
ColorForm2113 wrote:Murf and bode frequency shifter :D
Yes! and 2/3/4 stage phaser.
Croyote
Postby XAXAU » Wed Sep 23, 2015 4:04 pm
The Multidrive from the Sub Phatty & 37!
Why not the whole section from the synths on a pedal?
MF Filter - Cutoff - Resonance - Multidrive - Slope
XAXAU
Postby discONekt » Sat Sep 26, 2015 12:51 pm
4 Stage Phaser & a Spring/Plate Style Reverb. Then my full minifooger pedal board would be complete.
discONekt
Next
Return to Minifooger Forum
Who is online
Users browsing this forum: CommonCrawl [Bot] and 1 guest
