I just installed the Model D & Model 15 MacOS applications on my Mac (latest OS, last Intel version processor). The standalone applications work great. However, when I try to access them as Audio Units within Logic Pro, I get a fair amount of static along with the signal when I depress a key on my MIDI keyboard. At first, I thought it was volume-based signal clipping, but after changing gain settings, it's still happening (regardless of patch loaded on both Moog apps).
I do use other AUs in Logic Pro and they work fine.
I'm sure there's some Logic or Moog setting that clears this up, but I have yet to find one. Any ideas or pointers are appreciated.
Thanks, Steve
Model D & Model 15 static when using Logic Pro
Re: Model D & Model 15 static when using Logic Pro
I have this issue as well, but it is also the standalone apps. I figured my processor was too weak (2014 intel mac mini). Adjusting sample rates and buffer settings did not work for me, but maybe you have a mismatch between Logic's settings and the Moog plugin?
