I'm considering buying a Roli Seaboard to play with Animoog. (yeah, the Seaboard looks more natural to me than the Linnstrument layout, but I hope I'll be able to test a Linnstrument to find out to which extent I'm wrong
Here's what I found so far about Animoog and the Roli Seaboard. First, Animoog can be used even if it doesn't currently support MIDI over Bluetooth:
https://support.roli.com/article/using- ... ther-apps/
However, according to the next Roli documentation entry, Animoog doesn't appear to fully support the Seaboard capabilities:
https://support.roli.com/article/recomm ... bile-apps/
Anyone has experience playing Animoog with a Seaboard? What's your take? Is Animoog as limited as Roli indicates it is? Thanks! -- Alex / Satri"Animoog is a great mono-timbral instrument. Since Animoog is mono-timbral, it won’t provide polyphonic expression of Glide, so before using it with the Seaboard, set the Seaboard to Single Channel mode in ROLI Dashboard. Animoog also doesn’t currently respond to Slide, but will give great response to Press (aftertouch) and Strike (velocity)."
