Can't copy/paste 1.2.1
Is anyone else having trouble copying and/or pasting on iPhone in v1.2.1? I have AudioCopy installed, and when I press copy within animoog, it asked me to select the program to which to copy to, but it states that AudioCopy is "not installed." Same goes for the paste function. What gives?
iMac 27" OS X 10.10
Ableton Live 8.4.2
Moog Minitaur
Roland JX-10
Oberheim Matrix 6R, OB-6
Roland JD-990
Roland V-Synth
Strymon Timeline
MXR Analog Chorus
Way too many plugins
Ableton Live 8.4.2
Moog Minitaur
Roland JX-10
Roland JD-990
Roland V-Synth
Strymon Timeline
MXR Analog Chorus
Re: Can't copy/paste 1.2.1
Apparently I'm the only one.....
iMac 27" OS X 10.10
Ableton Live 8.4.2
Moog Minitaur
Roland JX-10
Roland JD-990
Roland V-Synth
Strymon Timeline
MXR Analog Chorus
Ableton Live 8.4.2
Moog Minitaur
Roland JX-10
Roland JD-990
Roland V-Synth
Strymon Timeline
MXR Analog Chorus
i'm facing the same problem in animoog 1.2.4 for iphone. please any answer to this problem. thanks
With Animoog-iPhone 1.2.4 on an iPhone 6S+.
When I select either copy or paste I get a dialog box that says
It always says the sample rate is 48000 Hz regardless of my selection.
Works correctly in Animoog-iPhone 1.2.4 and Animoog 2.3.5 on an iPad 2 and Animoog-iPhone 1.2.4 on an iPhone 5.
I found the preferred sample rate selection on the setup/Audio panel.AudioCopy only supports 44100 HZ.
Check the setup/configuration panel
to ensure this sample rate is active.
isferidis!are u also asking help for pasting problem??? because i am bit confused that about which problem you are asking for help..iseferidis wrote:i'm facing the same problem in animoog 1.2.4 for iphone. please any answer to this problem. thanks
I have exactly the same problem. Can’t get my music out!dtruchan wrote: ↑Wed May 25, 2016 5:10 pm With Animoog-iPhone 1.2.4 on an iPhone 6S+.
When I select either copy or paste I get a dialog box that saysI found the preferred sample rate selection on the setup/Audio panel.AudioCopy only supports 44100 HZ.
This is really upsetting to me.
Animoog was my favorite synth and one that I would be willing to pay a lot more for if it worked properly.
I ended up having to buy Audiobus in order to get it to pass to another app- but do not recommend doing this.
The audio copy feature used to work perfectly and now it's completely broken.
I just registered to open a ticket with support and have lost all faith in Moog seeing that this issue has been going on for 4 years.
I wont buy another Moog app again
