pedal contact mechanism on T3
I'm sure this has been mentioned before but I can't locate any details. What will the design of the pedal contacts be? More durable/less prone to "missing notes" than the T1?
- sixofthebest
- superd2112
Fatar manufactures the pedal & contact assemblys for Moog, and I believe they are the same ones used in my Roland PK-5s (also made by Fatar for Roland), so not to worry - my PK-5s are more than ten years old, have been through some pretty nasty club conditions, and have never once suffered a missed or falsely-triggered note. I don't believe they are metal wire contacts as used on the T-1s, I think they are something much more reliable.
Yep, this is correct.superd2112 wrote:Fatar manufactures the pedal & contact assemblys for Moog, and I believe they are the same ones used in my Roland PK-5s (also made by Fatar for Roland), so not to worry - my PK-5s are more than ten years old, have been through some pretty nasty club conditions, and have never once suffered a missed or falsely-triggered note. I don't believe they are metal wire contacts as used on the T-1s, I think they are something much more reliable.
It's the same topology as found in the Taurus 1. You can probably Google the schematic for it, which is found in the Taurus 1 service manual.EricK wrote:Amos,
Can you explain the filter topology from the product description?
With a couple early exceptions. This is certainly true of all modern (post-Big Briar) Moog synths. The product description doesn't mention the filter topology because it's something different than other Moogs, but rather because it's something different than most other modern synths (which are primarily digital, or analog filters integrated into monolithic IC's like in the Andromeda and Dave Smith intruments). That's all really...EricK wrote:Aren't all Moog synths generally with a transister ladder filter?
- latigid on
Trust me, the Voyager has proper ladder filters. They're comprised from modern components, you can't buy TIS97 transistors anymore.
