odd sirin legato behavior?
mistuned
Post by mistuned » Wed Oct 20, 2021 7:39 pm
I have a Sirin running firmware v1.0.1.
Legato mode seems to be working only gliding up in pitch -- not when gliding down in pitch. Does anyone have an idea of what might be causing this?
To clarify:
• If I hold on the C4 key (of my MIDI controller), and then press the C3 key, then the Sirin behaves as I'd expect it to: The pitch immediately glides down from C4 (262hz) to C3 (131hz).
• However — if I hold on the C3 key, and then press the C4 key, there is no pitch change. The Sirin simply continues to play C3 (131hz). The bend only occurs if I release the C3 key while still holding down the C4 key.
This makes it very hard to create MIDI sequences that make effective use of Legato! Any advice would be appreciated.
=Tim=
stiiiiiiive
Re: odd sirin legato behavior?
Post by stiiiiiiive » Thu Oct 21, 2021 7:02 am
Hi Tim, welcome to the forum!
I guess it's not a matter of legato but a matter of note priority. Your Sirin seems to be set in high note priority. Try other settings :)
mistuned
Post by mistuned » Thu Oct 21, 2021 1:52 pm
Aha -- "Note Priority" is the answer! Thanks Stiiiive!
