EG amount vs Filter Attack
Eldeederino81
Post by Eldeederino81 » Fri Oct 23, 2020 9:13 am
Hi guys,
trying to optimise my midi keyboard to control my Minitaur.
One thing I don't understand:
Why is MIDI CC for EG AMOUNT and VCF Attack the same number (22)
I understand the relation between the two but those are different parameters, right?
the function becomes then EG amount and I have to controle the filter attack manually, but then what about the sustain and release, those too are affected by the EG amount, but they do have their own CC's..??
till
Re: EG amount vs Filter Attack
Post by till » Sat Oct 24, 2020 12:12 pm
MIDI CC numbers taken from the manual I got here as PDF:
EG AMOUNT: #22(MSB) #50(LSB)
VCF ATTACK: #23(MSB) #55(LSB)
So not the same number for two different parameters.
What do you use as source for your MIDI CC numbers?
Sequence:
