I’m new please help me get sound out of my minitaur?
Miniclaw
Post by Miniclaw » Sun Sep 20, 2020 6:06 am
Hi all.
I’ve just bought a 2nd hand minitaur and I can’t get it to produce sound in my studio. Neither output work either headphone or output?
It’s receiving midi data from fl studio and the lights are blinking in sync so I figure it’s definitely receiving data but not emitting sound? With both vco’s level up and cutoff full tilt I’m getting nothing?
Somewhere I read sending cc7 msg might help? I’m unsure how to do this in fl studio?
( I did open midi out and select a knob then configured it to cc7 with range 0-127 then dialed it all the way up but still nothing?)
Does anyone have any suggestions?
I’m desperate at this point...
Thank you.
Miniclaw.
bichuelo
Re: I’m new please help me get sound out of my minitaur?
Post by bichuelo » Sun Sep 20, 2020 9:27 pm
Try using the official editor, you are able to download it from the site as soon as you register your product
That way you can change the volume CC 7 using your mouse, using the standalone version or the plugin. Maybe changing presets from there might make it work as well
http://audiotecna.info
Suspish
Post by Suspish » Mon Sep 21, 2020 2:38 pm
You will also want to make sure you are sending and receiving MIDI on the correct channel. The midi light will flash even if it is receiving on a different channel, but of course will only play notes when the channels match.
