Minitaur midi display solution
Posted: Sat Nov 18, 2017 3:31 pm
Hey all,
Trying to find the ideal way to move between presets on the Minitaur in a live situation.
I do my preset editing at home, using my mac.
Bringing it to a show only for this purpose seems to much of a hassle, plus I don't want to rely on a computer for this.
Since the minitaur has no screen, and my midi controller doesn't also (arturia keystep, which I like),
I found this:
https://www.midi-hardware.com/index.php ... uct=MIDisp
and this:
http://www.moltenvoltage.com/products/S ... ltage.html
I do also have a Moog MP-201. was wondering if it'll function as a preset display for the minitaur?
Thanks in advance
-N-
Re: Minitaur midi display solution
Posted: Mon Nov 27, 2017 2:22 pm
by Crazyfist
I don't see why it wouldn't! Great idea, the Molten Voltage looks a bit expensive but I can't think of any other equivalents. How are you changing presets?
Posted: Fri Dec 08, 2017 11:46 am
Thanks for your reply!
I think I'll give it a try, still haven't ordered it.
Currently changing presets through the editor/librarian.
Starting to use it live pretty soon so I'll figure out how to do that via the molten...
Any other ideas?
-N-
Posted: Mon Jan 08, 2018 3:17 am
by umbrella
Indeed you can use your MP-201 to do that (which has a display). MP-201 can be configured to send program change message whet its preset is selected.
Posted: Mon Jan 22, 2018 1:23 pm
umbrella wrote:Indeed you can use your MP-201 to do that (which has a display). MP-201 can be configured to send program change message whet its preset is selected.
Thank you,
I just PM'd you about that.
-N-
Posted: Sat May 12, 2018 8:56 am
by gon0360
I used to use a Midi Mouse from Tech 21 NYC as display.
In order to connect a MIDI Master Keyboard with a MIDI cable, I needed to use a "MIDI Merger" box as well.
Posted: Sun May 20, 2018 10:24 am
by brow
gon0360 wrote:I used to use a Midi Mouse from Tech 21 NYC as display.
how does that work with the minitaur? midi out from the minitaur to the midi in of the midi mouse?
Posted: Sun Jun 10, 2018 9:13 am
by Tsaddeous
No, it's the midi out of the midimouse, into the in of the Minitaur.
The problem with it, is when you recall a preset via your sequencer, the midi mouse don't receive it, because it don't have midi in.
I think we need same thing as the midimouse, but with a midi in too.
