Minitaur midi display solution
[email protected]
Post by [email protected] » Sat Nov 18, 2017 3:31 pm
Hey all,
Trying to find the ideal way to move between presets on the Minitaur in a live situation.
I do my preset editing at home, using my mac.
Bringing it to a show only for this purpose seems to much of a hassle, plus I don't want to rely on a computer for this.
Since the minitaur has no screen, and my midi controller doesn't also (arturia keystep, which I like),
I found this:
https://www.midi-hardware.com/index.php ... uct=MIDisp
and this:
http://www.moltenvoltage.com/products/S ... ltage.html
I do also have a Moog MP-201. was wondering if it'll function as a preset display for the minitaur?
Thanks in advance
-N-
Crazyfist
Re: Minitaur midi display solution
Post by Crazyfist » Mon Nov 27, 2017 2:22 pm
I don't see why it wouldn't! Great idea, the Molten Voltage looks a bit expensive but I can't think of any other equivalents. How are you changing presets?
[email protected]
Post by [email protected] » Fri Dec 08, 2017 11:46 am
Thanks for your reply!
I think I'll give it a try, still haven't ordered it.
Currently changing presets through the editor/librarian.
Starting to use it live pretty soon so I'll figure out how to do that via the molten...
Any other ideas?
-N-
umbrella
Post by umbrella » Mon Jan 08, 2018 3:17 am
Indeed you can use your MP-201 to do that (which has a display). MP-201 can be configured to send program change message whet its preset is selected.
Minitaur / MF Delay / MF Trem / CP-251 / Mac Mini / OS X 10.11.6
[email protected]
Post by [email protected] » Mon Jan 22, 2018 1:23 pm
umbrella wrote:Indeed you can use your MP-201 to do that (which has a display). MP-201 can be configured to send program change message whet its preset is selected.
Thank you,
I just PM'd you about that.
-N-
gon0360
Post by gon0360 » Sat May 12, 2018 8:56 am
I used to use a Midi Mouse from Tech 21 NYC as display.
In order to connect a MIDI Master Keyboard with a MIDI cable, I needed to use a "MIDI Merger" box as well.
brow
Post by brow » Sun May 20, 2018 10:24 am
gon0360 wrote:I used to use a Midi Mouse from Tech 21 NYC as display.
how does that work with the minitaur? midi out from the minitaur to the midi in of the midi mouse?
Tsaddeous
Post by Tsaddeous » Sun Jun 10, 2018 9:13 am
No, it's the midi out of the midimouse, into the in of the Minitaur.
The problem with it, is when you recall a preset via your sequencer, the midi mouse don't receive it, because it don't have midi in.
I think we need same thing as the midimouse, but with a midi in too.
