My Minitaur stopped wokring the other day and I found the fix on another website and thought I'd post it here. The unit had power and was receiving midi and the lights were working, but there was no sound from the audio out or the headphone out. I tried unplugging it and plugging it back in and it did the same thing.
The four-button trick worked. Just press and hold all four buttons on the front panel at the same time and then release. Then press a button on your midi controller. It resets the midi channel or something.
Anyway, it was a life-saver and I hope this helps someone!
Minitaur unresponsive... solution!
- Analog Prophet
Re: Minitaur unresponsive... solution!
Great, good to know if it happens - thank you for sharing!
http://www.soundofmusic.se
- stiiiiiiive
Don't have any Minitaur but thanks for sharing this
