Hi all,
Anyone had any issues with the Minitaur power supply causing noise in the audio output signal? Just today, I've been getting clicks and pops (smacks of spike in power) in my audio; definitely unrelated to envelopes or phase sync. I've tried changing out everything: USB, jack cable, and audio interface. Same issue.
Anyone had this problem?
Moog Minitaur Power Supply Issues
Re: Moog Minitaur Power Supply Issues
After further research, this is starting to sound like a VCA/pot issue:
viewtopic.php?f=11&t=20348
Here's a recording of the issue in play:
https://soundcloud.com/rickygraham/sets ... ch/s-DqzND
I've requested an RMA but would love to hear if anyone has any solutions or quick fixes?
Try a different PSU with the same voltage (12 Volts) and polarity (the outer is negative) and at least the same current (min. 1200 mA).
Maybe it is just the PSU.
Sequence:
Sequence:
