by Joscuzz » Wed Aug 09, 2017 5:03 am
Are you using Ableton's "External Instrument"? Unfortunately I can't screenshot for some reason, but my set up is like this:
External Instrument - MIDI To Minitaur Out Channel 1
Audio From - No Input
MIDI Channel - MIDI From Minitaur - All Channels - Audio To (Separate Audio track routed for this with "Monitor" On)
I have the Minitaur VST on the MIDI channel along side the External Instrument and all parameters are available including LFO Sync to MIDI option.
You might have to tinker with the config to suit your set up but I hope this helps in some way.
Strictly no bubblegum: Moog Minitaur, MF102, CP-251, EP-3, Komplete Kontrol S25, Maschine Jam, GAP PreQ-73, GAP Comp-54 MKII, TC Electronic Flashback Triple Delay, Spark, Dark Matter.
