Who makes the Software Editor for the Minitaur?
roscio9292
Re: Who makes the Software Editor for the Minitaur?
Post by roscio9292 » Tue May 09, 2017 7:34 pm
MR79 wrote:OK the new beta firmware and drivers are just....... PER-FECT!!!!!!!!
They will be available very soon!!!!!! And now I can have SO MUCH pleasure with my Minitaur with Live!!!!!! :twisted:
Hope so bro , i have exactly your setup :
Windows 10 64 bit / Ableton 9.7 / Minitaur
With ONLY USB hooked:
I can use the editor ONLY in standalone version .
VST on Ableton doesnt works as it says "Minitaur firmware version disconnected" : (on the settings of Live i tried all the combination with Track , Sync , Remote) and it works just if them all are disabled (this mean that i can't use External Instruments and then the Editor works but i can't hear the Minitaur sounds)
Actually i'm using USB + MIDI cable on the ext.audio interface :
On Ableton Track Sync Remote all disabled. (works only in this way)
Standalone still works ( i don't use it)
VST works BUT : i can't do automation directly using knobs from Minitaur , i must map the "FilterCutoff" on a different MIDI controller and then recording the automation , that's not really confortable.
Editor works fine but i have that problem for the automation.
ALL THIS WORKS ONLY WITH WINDOWS DRIVERS (Moog Drivers aren't recognized from windows error code 10)
So..i really hope the new firmware/editor will work perfectly with the only USB hooked.
Windows 10 64 bit / Ableton Live 9.7 /Minitaur
MR79
Post by MR79 » Wed May 10, 2017 6:47 am
Yes it's working perfectly.
Minitaur
Ableton Live 9
Win10 64bit
roscio9292
Post by roscio9292 » Wed May 10, 2017 8:09 am
MR79 wrote:Yes it's working perfectly.
Are you using only the USB to connect Minitaur to the PC?
MR79
Post by MR79 » Wed May 10, 2017 9:17 am
Yes, USB only.
You need the Editor 3.2.0, Firmware 2.2.0 and driver 3.30.0 to have all working great! ;)
Minitaur
Ableton Live 9
Win10 64bit
MR79
Post by MR79 » Thu May 11, 2017 4:34 am
OK the new driver/firmware/editor are working great now on Windows in Ableton. God job guys!!!
BUT...... Now you really have to find a way to add the changing of the preset name and knobs position when doing a pgrm change in the DAW.... Because it is finally the most important thing with the VST editor.... Without that, what is finally the real interest of the editor VST.....???
The big advantage to have the preset name and most important, the knobs POSITION, is that you really know "where" is your sound...... I'm sure you are understanding me, right? And I know you can do it for sure too!!!
It is a really most important feature.....
Without that, I sincerely don't feel a real interest to use the VST editor..... I can do prgm changes and automations directly in Ableton.....
So please do it!!
Thank you
Rene
Minitaur
Ableton Live 9
Win10 64bit
