I am running ableton 9 (32 bit) on OSX 10.12.3.
As far as I know all firmware etc. is up to date.
After many other hurdles, I've finally arrived at a point where my DAW recognizes the Minitaur, lets me change presets without any hassles etc.
I have an external instrument open with the Minitaur editor vst opened as an effect on that track.
I have a separate track recording audio.
I can record midi note data on the External Instrument track and Audio to that separate track without any issue.
I see parameters change on the editor interface when I manually adjust them on the hardware itself, but I see no recording of that data on the armed (separate MIDI) track. (although I see that it is receiving the data because one meter light appears on the armed MIDI track when I change parameters on the unit manually)
I am trying to route the MIDI in from Minitaur out to that track, hoping maybe the data gets recorded that way?)
That's as far as I have waded into this...
Any advice would help. Thanks.
