Minitaur not recognized by mac
advent
Post by advent » Sun Oct 23, 2016 3:32 pm
Hi there! I have an issue connecting newly purchased Minitaur to mac. USB cable itself works. Audio MIDI Setup does not recognize Minitaur as an audio device. So I don't see device to choose in SysEx Librarian and also cannot find it recognized by mac. Maybe someone has an idea of what to check?
jsharpphoto
Re: Minitaur not recognized by mac
Post by jsharpphoto » Mon Oct 24, 2016 12:40 pm
The minitaur isn't an AUDIO device. Only a USB midi. No audio is sent over the USB.
Moog Format Modular
Model D (2016)
Moog MG-1
Access Virus Ti2 Polar
Oberheim OB-6
Sequential Rev2
LetsFly
Post by LetsFly » Thu Mar 02, 2017 11:03 am
advent wrote:Hi there! I have an issue connecting newly purchased Minitaur to mac. USB cable itself works. Audio MIDI Setup does not recognize Minitaur as an audio device. So I don't see device to choose in SysEx Librarian and also cannot find it recognized by mac. Maybe someone has an idea of what to check?
Hey there.
Am having the same issue. Did you find a solution?
I tried to update it via midi and the Sysex thingy but now it`s stuck in "update mode" with lights flashing and can`t even use it.
But before it worked fine. Only it never showed up in Sysex Editor. Only i Live i could use it normaly via Usb. Go figure...
dirx808
Post by dirx808 » Sat Mar 04, 2017 9:43 am
It should show up in SysEx Lib dropdown simply as "In" ...Select that and follow the update procedure. This took me a bit to figure out but now works flawlessly.
And yes, it is not an Audio device, just a MIDI device so you will not see it in any Coreaudio options.
Hope this helps!
New Moogs: Sub 37, Minitaur - Ableton Live 9, Cubase 9, WaveLab 9 - Duet, UAD Apollo Twin + Octo - MacBook Air (10.11.6), Mac mini x2 (10.12.3) - MiniFooger Delay (x2), Drive and Chorus -- Legacy: Prodigy (Rev. 1), Juno-60, DX7 (Rev. 1 + Grey Matter E!)
