I have bought a Tech 21 Midi Mouse for changing the preset sounds on my Minitaur.
However nothing happens when I try changing the sounds via the footswitch. This is an imperative part of my live playing as I use up to 4 sounds in one song.
What (if anything) am I doing wrong?
Changing Minitaur sounds via footswitch
Re: Changing Minitaur sounds via footswitch
Have you set the midi channel on the Minitaur to be the same as the Midi Mouse?
Hold down all 4 big buttons on Minitaur. They should start flashing. Now send something from the midi mouse and that will change the Minitaur to what midi channel it should be on.
Thanks! It did the trick! I am indebted to you
Cool. Glad that was the problem and it's all up and runningSteveM wrote:Thanks! It did the trick! I am indebted to you
