Moog Music Forum
Share Ideas and Pass the word
Minitaur Note Range
Welcome to the Taurus & Minitaur Forum
Minitaur Note Range
Postby joelsampson » Fri Oct 09, 2015 5:05 am
Does the Moog Minitaur with current firmware now play higher notes or just lower bass notes? I never understood this limitation from a user stand point.
joel in Dallas
joelsampson
Re: Minitaur Note Range
Postby cousinofdeath » Fri Oct 09, 2015 9:34 am
it's a hardware limitation unfortunately, and it cannot be changed with a firmware update. that is my understanding. i suppose it was to keep costs lower, or to perhaps empha$ize that the minitaur is a bass instrument (though i use it for baritone leads from time to time as well)
Minitaur (sequenced via MIDI with an MPC1000 and USB w/ mac running OSX 10.10)
MF-101 Lo-Pass Filter
MF-103 Phaser
cousinofdeath
Postby bichuelo » Tue Oct 20, 2015 4:55 pm
I understand that the nature of the oscillators and the filter would not work properly on a higher register, it is not based on costs but in the sound itself, which would've been sacrificed if it had a bigger range.
http://audiotecna.info
bichuelo
Postby jsharpphoto » Wed Oct 21, 2015 12:21 am
The updated firmware just gave you the option to have it wrap the scale. Meaning, it would play the highest octave of that particular note, vs the old method of just getting "stuck" on C3. Personally, I never really play much above there for for the types of sounds I make with my minitaur(s).
Live Modular System - https://www.modulargrid.net/d/racks/view/305256
Studio Modular System - https://www.modulargrid.net/d/racks/view/352385
Model D (2016)
Voyager XL Maple
Sub37
MG-1
Novation UltraNova
Arturia BeatStep Pro
jsharpphoto
Postby MC » Wed Oct 21, 2015 11:54 am
Most VCOs are v/oct (volts per octave) - in a one volt per octave system, a one volt increment doubles the frequency (octave change). These are exponential VCOs.
A cheaper simpler VCO can be built to operate on v/hz (volts per hertz). Doubling the voltage doubles the frequency (octave change). These are linear VCOs. But linear VCOs have limits.
The original Taurus was built with v/hz VCOs. To stay faithful to the original design (and its huge bass sound), the Minitaur and Taurus III are built with v/hz VCOs.
In a v/hz VCO, you double the voltage to raise the frequency one octave. There are limits to the voltage - you can't exceed the power supply rails in the synth, and you can't have too low a voltage or error signals inherent in the opamps/transistors will throw off the pitch (can't be calibrated out). The power rails limit the upper frequency, and the opamp error signals limit the lower frequency. For a bass synth the lowest frequencies are designed to make the error signals insignificant (you don't want pitch drift, do you? Didn't think so).
Using a v/hz VCO, assume that 1/2 volt establishes the lowest frequency. To raise it an octave, it is doubled to 1 volt. A second octave, double 1 volt to 2 volts. A third octave, double to 4 volts. A fourth octave, double to 8 volts. A fifth octave, double to 16 volts STOP our power supply rail is 15 volts, cannot go higher than that.
So we got four whole octaves with a v/hz system. It doesn't take long to reach a limit.
Contrast that with a one volt per octave VCO with 1/2 volt establishing the lowest frequency. To raise it an octave, we add one volt resulting in 1.5 volts. A second octave, add another one volt to raise to 2.5 volts. Third octave, 3.5 volts. Fourth octave, 4.5 volts. Fifth octave 5.5 volts (still under power rails!). We can add another nine octaves up to 14.5 volts and still be under the power supply rails, and we got 14 octaves total. This is a hypothetical case for illustration, most synth v/oct VCOs have a ten octave range; higher ranges need some error correction of their own (read: more $$$), and a ten octave range has been plenty since the 1960s.
Linear v/hz VCOs also are not easy to modulate. A pitch bend on 1/2 volt may yield a pitch change of 1/4 octave at one note, but as you play other notes the pitch change using the same 1/2 volt won't be the same! That is why the original Taurus did not have an LFO or pitch modulation of any kind (I do not know how it is accomplished in the T3/Minitaur). Exponential v/oct VCOs are much easier to modulate, which is why they are more prevalent in synths.
MC
Postby CleverConQueso » Mon Oct 26, 2015 3:46 pm
I'm logging in here just to thank you for that excellent lesson.
CleverConQueso
Return to Taurus & Minitaur Forum
Who is online
