midi vs cv
Bertotti
midi vs cv
Post by Bertotti » Wed Sep 02, 2015 9:59 pm
I am curious, just got the miniature and I am reading the manual but maybe I have confused myself. If almost everything is midiable then why have cv? Does it eve differently when controlling a parameter then using midi to control the same parameter?
jsharpphoto
Re: midi vs cv
Post by jsharpphoto » Thu Sep 03, 2015 1:49 am
Cv is for connecting with purely a along gear. I would t connect with CV if midi was available, simply because I like remapping the CV inputs, and "pitch" and "gate" makeup for 50% of those opportunities.
Moog Format Modular
Model D (2016)
Moog Subsequent37
Oberheim OB-6
Sequential Rev2
Bertotti
Re: midi vs cv
Post by Bertotti » Thu Sep 03, 2015 5:49 pm
That is where I am hung up. I am looking into a midi to cv converter but so far I haven't gotten far enough in my comparison to see if midi will do everything cv does. I don't mind remapping especially if it is for something I can not accomplish with midi alone. I just don't know enough to know if having some cv along with midi would be redundant. Thanks!
jsharpphoto
Re: midi vs cv
Post by jsharpphoto » Thu Sep 03, 2015 9:14 pm
it's hard to say if "midi does everything CV does" because "what cv does" varies by each piece of gear. If you're specifically talking about the minitaur, then yes, midi can do all of that. The reason for having both, like i said, is to incorporate gear that isn't midi. There is also an added bonus of being able to incorporate multiple sources all feeding the minitaur. For instance, you could be sending midi notes and automations from a DAW, while you have CV coming from a sequencer that's doing other things, or synced with other gear.
I have two minitaurs and a sub 37. I use the 4-way multiplier in the CP-251 to be able to modulate all 3 filters with the same LFO. You COULD do that with midi, if you're clever, but not on the fly and with the flexibility that CV gives you.
Moog Format Modular
Model D (2016)
Moog Subsequent37
Oberheim OB-6
Sequential Rev2
jsharpphoto
Re: midi vs cv
Post by jsharpphoto » Thu Sep 03, 2015 9:15 pm
Out of curiosity, why do you need a midi-to-cv converter?
Moog Format Modular
Model D (2016)
Moog Subsequent37
Oberheim OB-6
Sequential Rev2
slabwax
Re: midi vs cv
Post by slabwax » Fri Sep 04, 2015 12:16 am
jsharpphoto wrote:Out of curiosity, why do you need a midi-to-cv converter?
i'm not sure This is what you're asking but here I go.
I use my Sub37 midi out into a modular midi to cv converter to control my small 5U modular synth or my Oberheim SEM patch panel that does not have midi.
jsharpphoto
Re: midi vs cv
Post by jsharpphoto » Fri Sep 04, 2015 12:24 pm
Got it. Makes perfect sense. I thought you were trying to use a midi to cv converter to control the Minitaur.
Moog Format Modular
Model D (2016)
Moog Subsequent37
Oberheim OB-6
Sequential Rev2
Bertotti
Re: midi vs cv
Post by Bertotti » Fri Sep 04, 2015 2:05 pm
jsharpphoto I was under the impression cv would give me control that midi wouldn't in the minitaur. I am quite happy to find out it doesn't! You helped a lot thanks!
Can I ask how you like working with two minitaurs? Do you layer them together for insane fat sounds or are they doing different roles?
jsharpphoto
Re: midi vs cv
Post by jsharpphoto » Fri Sep 04, 2015 4:58 pm
Bertotti wrote:jsharpphoto I was under the impression cv would give me control that midi wouldn't in the minitaur. I am quite happy to find out it doesn't! You helped a lot thanks!
I use them three ways:
1. Stereo bass phatness.
2. Sequenced separately as unique voices by the Beatstep Pro
3. Polychained to the sub37.
Moog Format Modular
Model D (2016)
Moog Subsequent37
Oberheim OB-6
Sequential Rev2
Bertotti
Re: midi vs cv
Post by Bertotti » Sat Sep 05, 2015 9:05 am
I am liking this Minitaur so much I was thinking of adding another but I am constantly deciding if things are to redundant do I really need it. Money gets tight so I get over protective of how I spend it. I do want a Sub37 so I am tossed up if two Minitaurs would be my direction or save and delay a sub 37 for another 4 months. 1 and 2 look like fun well 3 does also but I don't have that yet. I think first I will learn how I want to best exploit it with a Kronos. Thanks again!
jsharpphoto
Re: midi vs cv
Post by jsharpphoto » Sat Sep 05, 2015 9:38 am
Having two is definitely a luxury. I would get the sub 37 next, and then another Minitaur, or maybe a used slim Phatty (or little Phatty)
Moog Format Modular
Model D (2016)
Moog Subsequent37
Oberheim OB-6
Sequential Rev2
Bertotti
Re: midi vs cv
Post by Bertotti » Sat Sep 05, 2015 9:56 am
I have the same line of thinking, that sub37 is just to damn cool. Thanks
Bald Eagle
Re: midi vs cv
Post by Bald Eagle » Sat Sep 05, 2015 2:12 pm
All this talk about the Minitaur has my GAS acting up again. I already have a Sub Phatty and a Sub 37. I read somewhere that the Sub's have the Minitaur's oscillator core so I'm wondering if a Minitaur will bring anything more to the table. Any thoughts?
Bertotti
Re: midi vs cv
Post by Bertotti » Sat Sep 05, 2015 3:29 pm
Can't help much but wouldn't it be nice to have another Moog voice in there! As you can ss I am happy to enable! 8)
jsharpphoto
Re: midi vs cv
Post by jsharpphoto » Sat Sep 05, 2015 5:51 pm
I believe the Minitaur/Taurus have different filters. They sound different to me, and I think it was mentioned on here before. For me, the minitaurs are just kind of a great utility to have. Paired with another moog it can be whatever you need, at any given moment.
Moog Format Modular
Model D (2016)
Moog Subsequent37
Oberheim OB-6
Sequential Rev2
